DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Mon Apr 13, 2015 6:59 pm
Unfortunately hesitation is a problem with a lot of potential culprits, so first off let me say to check the stickies at the top of the page where thee is an area about hesitation and some quick help. The Online Service Manual is also of value with a lot of tests to narrow down the problem if an obvious culprit is not present.
I will take a stab however given your description of the problem and brief background to say to check for a vacuum leak, somewhere around the area (s) you may have worked as you mentioned battling numerous other issues (may help to mention them?), and around the throttle bodies and balance tube (tube bar on back of engine/top of intake manifold), being sure to check the larger Idle Air circuit tubing for cracked/pinched/unplugged. Check the vacuum tubing to the fuel pressure sensor and anywhere else you can see or may have brushed against/removed to access something else.
Hope this helps?
