Boiling Break Fluid
Edub1
Car: 89 240sx KA-T
I'm a little worried with how close my turbo is to my break cyclinder. More specifically, the lines coming from the side. Anybody ever hear of anyone boiling the fluid in these lines and loosing pedal?
C-Kwik
Yes. Might look into turbine heat shields and heat wrap to protect the master cylinder and brake lines. Don't forget the plastic reservior which can melt as well.
Florida240sx
No they can't.........
Florida240sx
$2 solution....
C-Kwik
Florida240sx wrote:No they can't.........
LOL...nothing that duct tape can't fix...
98240
you can go to a kragens, napa or autozone and they have this exhaust system repair kit that can stand up to 2300 degrees of heat. it cost like 6 bucks
Edub1
Car: 89 240sx KA-T
I have my MC wrapped in header wrap and then have a piece of 5" stove pipe around it with a .5 inch gap inside so MC should be good.
Will simply wrapping the lines and most of the turbine be enough?
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
I made a heat shield Out of thin sheet metal, I used the BMC bolts and one of the bolts that used to hold the coil to hold it on and I have never had a problem.
lrb_2000
Car: '91 Nissan KA-T hatch
98240 wrote:you can go to a kragens, napa or autozone and they have this exhaust system repair kit that can stand up to 2300 degrees of heat. it cost like 6 bucks
what exactly is that?
