redsx13 »
https://forums.nicoclub.com/redsx13-u72643.html
Tue Dec 30, 2008 7:26 pm
well you have the proper maf, its from a 180sx.The white wire is your signal wire and i dont see any reason why there would be another wire crimped to it, but someone put it there for a reason, only thing i can think of is that there was somthing wrong with your original signal wire and someone ran a new wire from the ecu to the maf. (p.s. on the oem setup, both the maf ground and signal wires are wrapped inside of an additional black wire, so make shure you are not confusing that black wire with the one on your car.) there isnt anything serously wrong, if ther was, the car wouldnt run.
as far as the bogging, a little more description would be helpful. driving conditions, weather......
