Correct me if Im wrong but don't our cars have more than one O2 sensor? Also, FPR? Sorry I'm not familiar with that terminology...biggie wrote:If you actually suspect the O2, just replace it, only like $15 for a new Bosch at parts store I believe.
If you are running rich and its not the O2 could have air/vaccum leak, FPR could be bad, or leaking around injector maybe.
It will go past 65... just cruising at those high speeds is when the problem becomes apparent. Would the fuel pump be cutting in and out? I feel like fuel pump either works or doesn't work... Almost feels like a leaky injector...?gijoe392003 wrote:FPR = Fuel Pressure Regulation and yes, only one O2 sensor. If it feels like that car is struggling to go past 65, then that is definitely a fuel issue. Most likely the fuel pump. If it feels like a fuel cut and the engine doesn't respond, then that is the 4th or 5th gear sensor.
Thanks. Gonna try cleaning the TB and MAF today and see if that helps at all. Also, I don't know if this problem has anything to do with the bogging or the IACV prob that Im having as well, but in the mornings (its cold in NJ), the car has trouble running. I'll go out to start in to warm it up and when I come back out to go to work it has stalled. Today I waiting in the car to see how long it takes the car to do it and within 2 minutes the car stalled out. RPMs dropped and fluttered around 500-600 and then it stalled. Does this have to do with the bogging prob Im experiencing or my dirty IACV?gijoe392003 wrote:I know I am having a problem with my fuel pump being clogged by crap in the tank. I just suggested the fuel pump because of my issue but it could be the filter, FPR, or injectors.
Im from South Jersey, Cherry Hill, are you from jersey?S13_RB25 wrote:It could be miss fire caused by a vacuum leak?? Oh also where NJ are you??
I agree, had DC headers too.asoomal wrote:I doubt it's the O2. The ECU doesn't even use it much, you can run it disconnected and you wouldn't notice anything. I ran one without one for a year cause I was too lazy to hook it up (DC Headers).
Im from South Jersey, Cherry Hill, are you from jersey?NICONick wrote:S13_RB25 wrote:It could be miss fire caused by a vacuum leak?? Oh also where NJ are you??
NICONick wrote:
Yea I'm in Burlington township after I get my s*** running we should meet up...
yea sounds good jsut pm me or somethingS13_RB25 wrote: Yea I'm in Burlington township after I get my s*** running we should meet up...
It does! Thanks! Anyone know if it's worth saving the $30 to go with those brands as opposed to Walbro?S13_RB25 wrote:Well i looked around walboro is $100 but i found isis and a circuit sports 255 lph fuel pumps from $70 to $75. The isis on http://www.240sxmotoring.com/ishi255ltfup.html and the circuitsports on http://www.frsport.com/Circuit-Sports-2 ... 12477.html
Hope that helps!!
ERG? Did you mean EGR?SC90S13 wrote:possibly a clogged ERG system
