CrazyTrance »
https://forums.nicoclub.com/crazytrance-u27545.html
Wed Aug 13, 2008 4:27 pm
So i timed it with the alternator and water pump not hooked up to my pulley and i got the timing right on, the cas was practically right in the middle. Then i timed it again after i put my radiator back in and the belt back and timing was off. To get it to the third notch from the right (15 degrees) i had to turn the cas all the way to the right ( or retard it all the way) .... seems like it shouldn't be there.
Also, when i drive it. If i touch the gas pedal even slightly more than 1/8th throttle it bogs like there is no tomorrow... wtf. I think it only does this under load.
It does this when the maf is both unplugged and plugged in. But when it's unplugged it doesnt wanna stay running.
HELP!
