jlain »
https://forums.nicoclub.com/jlain-u128251.html
Tue Mar 03, 2009 6:25 pm
I'm having an issue with my RB20 bogging down at low rpm. When taking off giving a normal/low amount of gas, the car will bog down for a second or 2 while it gains speed and then regain power around 3500-4500 rpm's. It really takes off when power comes back. The issue is very hard to describe. Here is another situation. After slowing to 10-15 mph, put in 2nd gear, and giving the car normal/low gas the car will bog down, if I give it more gas the car acts like its being held back until it eventually gets up in rpm's and then takes off with the quickness around 4000 rpm's.
What I done so far.New coolant temp sensor - This helped a bitCleaned out MAF. - Also helped someChecked for boost leaks - Can't see any issues.
I've read through about 20 different threads with similar but different issues. Any help would be great.
-Joe
