slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Sun Apr 24, 2005 2:47 pm
Also check your throttle position sensor, it's easy, and it fixed a lot of my hesitation/stumble problems:
With the car warmed up, engine off, key in the 'run' position, and the TPS sensor *plugged in*, push a needle into the back of the connector, along side the wire. Do this for the black and the white wire(three wires total). Read the DC voltage with a multi or voltage-meter. The voltage should be between 0.4-0.5V with the throttle completely closed. If not, you can adjust the sensor by loosening the two bolts holding it in place.(7mm wrench was the only way I could get to it).
HTH
