Bog After Start. Vaccum Problem?
dhkemp91
Car: '94 Nissan 300ZX NA
Alright I am a new Z owner. I have always wanted one and finally got one a few weeks ago and im learning something new every day about them. Everything seems to be good on it but recently when i was looking under the hood i saw what i am pretty sure is a vaccum hose not hooked up to anything so i hooked it up and then when i start the car it will start then immediately die and most times not even start again. So i went back and unplugged the hose again and the car runs fine. I know the hose should be hooked up so what else is causing this?
Thanks !
CRPZ
Car: 1990 Cherry Red Pearl Nissan 300zx Twin Turbo
:welcome:
Hope to see you around the forums!
As for your question.. unfortunately I have NO idea. :/ I'm sure someone here will have an answer for ya!
JaredM
Car: 1990 z32-300zx
welcome,
where was the hose located?
nissanfreak12
Car: 92 300zx 2+2 TT
Im gonna throw this out there, is it on the passenger side toward the back? If so it may be your EGR malfunctioning when you plug it in, sounds like exactly what happens when the egr is opening too soon or all the time.
NolimitZ32
Welcome, ^Ditto, post a pic of the hose. And in the future please keep questions like this in Technical.
dhkemp91
I will post some pictures tonight. And I do apologize for the incorrect posting section. It is on the passenger side but it is towards the front. Looks like it connects to one of the main intake tubes that then goes directly to the engine. Don't know if that description is accurate but I will get some pics up here ASAP.
NolimitZ32
Does it connect to the top of the pipe or the bottom?
dhkemp91
Here it is, I guess its kind of on the bottom.
And here she is, What do you guys think?? I have big plans for her! haha.
Hope This helps or sparks some ideas! Thanks again!
nissanfreak12
Your idle is set too low. That hose being unplugged is putting more air in the engine keeping it from dying. It also may be the IACV may be dirty. Everything in here should or hopefully get you in the right direction.
http://api.viglink.com/api/click?format ... 0054897581
nissanfreak12
And this one...hopefully this will do the trick.
http://api.viglink.com/api/click?format ... 0057083981
nissanfreak12
Are those the G35 wheels? How do you like them? Sorry to get off topic.
dhkemp91
Thanks for the links that will give me a solid place to start. it idles just sitting over 1k. i dont think thats really all that close to normal is it?
And they are 03-05 350z 17" wheels. I personally love them.
nissanfreak12
I believe being a 5 speed, it should set at 750-800, maybe even lower. I would really look into the IACV maybe take it off and give it a good clean. I know one of these guys on here sprays wd-40 in the to lubricate it every so often, like every six months. Then after that set the idle, even maybe play with the idle before cleaning see what happens.
I really wanted to get the G35 19" rays, but those rims are just too big for my taste. The wheels are gorgeous, but I like my kidneys. The wheels on your car look good, I may actually look into them, but keeping my options open.
dhkemp91
Yeah that's kind of what I thought. Ok I will try that today and see if I can figure it out. I'll post back later with any progress or problems!
Thanks again!
Yeah those are good lookin wheels but I think 19s are just too big too.
