lightsout »
https://forums.nicoclub.com/lightsout-u71638.html
Mon Aug 13, 2007 12:29 am
i ended up taking her into the dealer b/c i could not get her to run right. I did everything that i felt comfortable doing, without damaging her any worse.
before i took her in i replaced:Bank 1 Oxygen sensor.Crankshaft sensor.Camshaft sensor.Coil Pack on cylinder #6....i also took the throttle body out(btw it was naaaasty) and cleaned it thoroughly(even used Qtips to get into all the cracks. I did have a P0505 code(idle control malfunction) from the OBD II, and decided to take the Idle control sensor out and clean it with Qtips and the proper cleanser. That did not work either.
The dealer did a scan of the computer and got more codes after i turned her in.....to make a long story short. After almost $2K worth of repairs she runs perfect...she had lost her mind(PCM), and the doctor put her back together. All i have left to do is replace the idle control unit, clear the code, and she's good as new!!
thanks to everyone again, you've been a great help.
btw....pics of the rims are comming shortly, you're gonna LOVE 'em!!
Devin
