Bodykit questions - Please help!
Hey guys - A few questions:
I've ordered a bodykit for the S13 from Chris at Underground (great price!). It's fiberglass-reinforced plastic. I need to know a few things...
(Pardon my stoopidz, I haven't messed with a body kit since a front wing on a late 60's GM musclecar.)
How does the kit attach? I assume the front and rear simply replace the stock bumpers and use the stock hardware?
How about the sides? How do they attach?
How well do these typically fit? Do they require a lot of cutting / sanding or is it pretty much a "prime-paint-and-attach" deal?
Can this be done without a bodyshop? Without damaging my factory paint? Do i gotta drill holes?
Anything else I should know?
p.s. I got the DFTR front and sides and the Vertex rear, looks like the pic in the Heavy Throttle banner to the left.
PGBrian
i'll draw you a picture
BAMPERSnormal folk - bolts, screws, nutsme - zipties
SKIRTSnormal folk - screws, rivits, double sided tapeme - zipties
FITMENTif it is a quality company, fitment is perfect. no trimming or altering necessary
LOCATIONdo it at home, unlesss you suck at tools and thinking.
DFTRwell, this is the raceon kit? better get out the dremel to cut those *****es to make them fit.you picked BAD FITMENT.
PGBrian
oh, i saw that you bought the REAL stuff.well, your job just got much easier.
yashin
Car: football, rugby
Like he said bolts or zipties, you can also get them molded on, but I wouldn't recommend them.
It's kind of late now, but try to stay away from fiberglass. Either get urathane or blue-class fiberglass.
PGBrian
what is wrong with fiberglass?
TrunkMonkey
Car: 2000 Lincoln Navigator
fiberglass doesn't flex. the kit is FRP (fiberglass reinforced plastic) which isn't too bad. urethane is the best.
-demetrius
TrunkMonkey
AZhitman wrote:p.s. I got the DFTR front and sides and the Vertex rear, looks like the pic in the Heavy Throttle banner to the left.
i hate you.
-demetrius
marshun
yashin wrote:Like he said bolts or zipties, you can also get them molded on, but I wouldn't recommend them.
that blue class **** is a gimmick. trust me. i've dealt with it.
BomexS13
Car: '89 Nissan 240SX
'00 Toyota Celica
THe front and back bumper just replaces the stock ones and uses the stock holes. YOu said you got the REAL one so the holes should line up good.
As for the sides, you have to screw it underneath the fender well by the fenders.
yashin
marshun wrote:that blue class **** is a gimmick. trust me. i've dealt with it.
No. It's not. You clearly haven't worked with good quality blue class fiberglass.
I've worked with a large company that makes it.
Blue class is MUCH more flexible than regular fiberglass. Trust me. I have pics if you'd like. R
Real fiberglass has a habit of breaking very very easily. Blue class fiberglass **if done right** is very flexible.
tar0icy_w/tapioca
Car: cars for now
i think u just need to get the kit, lay it out and see how it fit, then take ur time and modify it to fit the way u think its best, and i would use bolts because zip ties to fail, use zip ties to reinforce if u must but i wouldn't count on itfiberglass is less dependable but cheaper to makethe kit u got sounds like a well made one though i would count on it cracking
Altiman94
Car: 1989 Nissan 240SX
do you plan on doing this yourself greg or having a body shop put it on and hten paint it for you all in one big step?
I plan to prep, paint and install myself.
I bought the 'vert as a PROJECT car, which means I intend to do all the work.
I'm currently rehabbing a NASTY set of JDM-only rims...
Altiman94
have you had car painting classes before greg? Im just curious since you plan on doing it yourself. I wouldnt trust myself near a paint gun
yashin
what rims?
I have restored a couple antique cars, had one in World of Wheels 1989.
Rims = JDM Racing Sparco Speeders.
