body kits & tires
primitifs
Car: 2006 G35 Infiniti Coupe, 2001 Dodge 4X4 Cummins, 2003 Custom bike,with 97"S&S Tangelo pnt.
OK I'm thinking body kit only I don't want to screw with the resale value as I will probably buy a 09. Does anyone have any experience with this issue? Also my tire dealer does not recommend up sizing my tires to 245/35A-19 &275/35A-19 as it will effect the ABS and more. Is he right?2006 G35 6 speed sport tuned suspension.
joe603
Car: 2014 Durango R/T
I run those tires... the dealer is either blowing smoke, or doesn't know the car. The 245/35-19 and 275/35-19 tires are within 1.2% of stock.
front is +2mmRear is -4mm
The ABS and VDC will work fine.
Consider this, simple tire wear and PSI #'s have more of an impact than those sizes do...
Check out this site to plug in different tire sizes: http://www.bigcustomwheels.com/info_specs.jsp
2mhighside
Car: 06 G35 Coupe MT
Ive learned not to listen to one single thing that comes out of anyone's mouth at the dealership. You will get more right answers out of asking questions on here. Your VDC or ABS will not be affected running larger tires. I have 20's on mine and the only problem is i have it slammed with coil overs and it tends to wear the inner edge of the tire. But god it looks sexy!
