bcar240 »
https://forums.nicoclub.com/bcar240-u13477.html
Wed Oct 13, 2004 9:34 pm
well, if you want a solution, also check the following:
IAAIACVvacuum systemMAFSTPSgrounding wires/electrical connectionscoolant temp sensoro2 sensora/c compressor function
amung about 1000 other things that can cause low rpms and / or bad idle. Just tryin to get some facts first. (although the brake booster check valve would be a good place to start considering the circumstances, good call 180fan.) The valve in question is in the big line running to the brake booster, and has tubing clamped on each side. Here is what the FSM has to say about the check valve, notice the cool diagram!
