bvanev »
https://forums.nicoclub.com/bvanev-u8898.html
Sun Mar 30, 2003 11:28 am
A friend of mine was having the same problem with her 240. I originally had the motor that is in her car, I installed it in her car after I bought my SR. When I had the KA it ran fine. About a year later she starts having major idle problems, so bad that she had to raise the idle to 1700rpm to keep the damned thing running. When I got a chance to check the motor out, I found a faulty MAFS (did not trigger the ECU into fail safe mode), broken O2 sensor (the bulb was shattered), a dirty air filter, and a completely clogged fuel injector. ALL IN THAT ORDER. The fuel injector was the biggest problem. Her car never let out any black smoke, but all of the seals where good in that car.
With my SR I currently have the following problems and symptoms. Extremely low idle, 500-600rpm, idle hunts and will stay running (after an upgrade in plugs) even under load. Gray smoke (combination of black and blue) caused by fuel in the oil, reducing the viscosity to near that of kerosene, this allows small amounts of fuel and oil to seap by the piston rings and be combusted, resulting in foul smoke. The fuel got into the oil by means of a faulty fuel pressure regulator. The diaphram broke and as a result left me with insanely high fuel pressure, causing a very over rich mixture.
I plan on fixing my problems by:1. An oil change2. Idle screw adjustment (fully closed at the moment)3. Ignition Timing adjustment.
Hope this helps.
