BMI AMERICAN TOUGE 2 casting call!!
sleepyRPS13
Car: to sleep
if you dont know about it or did know but forgot . here is the link
http://www.bestmotoringvideo.c....html
240DRFT
hey is that white 350z our member hatebobbarker??
sensibleS13driver
I think it is with a DDay instructor driving.
sleepyRPS13
Car: to sleep
if my car was more capable would bring it. i can already predict the comments: suspension to soft; this motor has no power; damn this tire sucks balls; what the hell is that gas smell, is it leaking. me: i think it needs new oring & hoses, sir.harharhar
that toyota echo serious its rolling with work equips o3.
JDMEnthused
Car: Nissan 240SX
mmm id love too .. BUT! i need new rear toe links, unfortunately.
HashiriyaS14
Car: '95 Nissan 240SX
'08 Honda Accord
'08 Honda NPS50
'03 Kawasaki Ninja 250
'60 Honda Super Cub
lol, did you see the Toyota Echo with the Work Equips on it?
That's be awesome if someone built a fast Echo.
sleepyRPS13
Car: to sleep
i wonder if it has a 2zzge swap and if i remember correctly it has a curb weight around of 2500lbs.
lightweight+170hp?+6speed?+sticky tires=one fast touge echo.
HashiriyaS14
'08 Honda Accord
'08 Honda NPS50
'60 Honda Super Cub
sleepyRPS13 wrote:i wonder if it has a 2zzge swap and if i remember correctly it has a curb weight around of 2500lbs.
Yeah, that'd be the coolest thing ever.
I want a 2ZZ-powered Vitz, although I want a 2ZZ-powered MR Spyder even more
dickie
Car: Killer Turtle
i have a question/observation:
an echo looks like an egg. its short, narrow, and tall, which makes for a high center of gravity... even on a great suspension wouldnt you encounter more roll than another car?
SOHCSE
Car: 1990 240sx SE
d!ck wrote:i have a question/observation:
Just cut the top off!
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
i'd just like to point out that looks are and always have been decieving...
you cant simply say a car has a high center of gravity from its shape. its not like it has 30 inch tires, a grip of clearance and is actually a 4runner....
the most important part of the handling equation was 2500 lbs.
dickie
Car: Killer Turtle
thats true, i guess you could gut the headliner and throw a few bags of rock salt on the floorboard or something... :P
edit: what i was trying to get across is that for the price of that car he could have easily gotten something better suited for that type of driving and afforded to dress it out nicely. but i mean, then he wouldnt be driving an echo, and he wouldnt be such an individual in a world of conformists.
sleepyRPS13
Car: to sleep
i think that 350z does belongs to hatebobbarker
heres the echo
Specs:2000 Toyota Echo 4dr1.5L 1NZ-FE 4cylinder 5speed FWD motor2320lbs with 250lb driver
MODS:=engine mods= -E.L. Prototypes Cold Air Intake -E.L. Prototypes Header -Spec Stage 2 Clutch with Kevlar segmented disc -Tom's 7.8lb Lighten flywheel -Perrin lighten Crank pulley -Koyo Radiator-Mr. Gasket 12" Electric Fans-Samco Radiator Hoses-Apex'i S-AFCII -200cc 1999 Corolla 1zz-fe injectors -Apex'i EL1 Tach -2.5" E.S Tunning Muffler -2.25" exhaust piping from header -2.5" in/out Celica 2zz-ge resonator -2.5" in/out Celica GTS 2zz-ge cat-2.5" Moroso Spiral Muffler ( for the streets)-2.5"Striaght pipe (for the track)-4" Sebring tip -Custom blue grounding kit -Hawker Odyssey 15lb battery PC680 -Motul 8100 Excess 5w40 Oil ( for the street )-Motul 300V 5w40 Racing Oil ( for the track)-Motul Gear 300 transmission fluid
=suspension mods= -Custom revalved and destroked Tein Super Streets -Swift Competition spring... 7kg in the front and 8kg in the back-TRD Motor Mounts-Cusco Camber plates -Cusco mid frame brace -JIC front suspension bar -DC SPort strut bar -TRD rear frame brace -Ebay copy of a Do-Luck center floor brace -White rear sway bar -2004 Scion XA front Brake Calipers and Brackets-Custom stainless steel braided lines-EBC YellowStuff brake pads-EBC Sport Dimpled and Slotted rotors--Motul RBF 600R Brake fluid-Upgraded poly urtheane bushing for my front sway bar
=interior= -Scion XA Driver and passenger seats (for street use)-Vitz Center Console-TRD shift ball -Tom's steering wheel ( for track use) -Tom's horn button -TRP 75mm Hub extender -Nardi Boss hub -Nardi steering wheel spacer -Razo pedals -Crow enterprise harness bolts -Sparco EVO L ( EVO II new edition) complete with sliders and custom rails -Custom Pass Performance Harness bar -5 point Crow Enterprise harness -Vitz arm rest -Scion XB 6 Disc CD/MP3 players-Carbon Fiber Vinly Head Liner, door inserts, and sun shades
=extrior= -15x8 Work Equip O3's with Falken Zeix 512 195/60-15( For Street Use)-Raybrig wireless remote yellow fog lights -Narva Gold all weather bulbs -SUVLights.com upgraded head light wiring harness -14x7.5 Panasports (ProRally model which is for Racing Purpose only) -205/60-14 Toyo Proxes RA1 road racing tires
Soon to be installed in November:-Blitz Supercharger-Pulley Boys Crank Pulley ( to boost supercharger to 7psi)-Power Entriprise Camcom VVT-i controller-Elemental Design Audio System
best time is 1:30 ( N/A ) in Streets Of Wilow
p.s. I'll post vids when the site thats hosting them isnt down
wow
sleepyRPS13
Car: to sleep
videos
echo chasing se-rhttp://videos.streetfire.net/P...4C222
hunting a 400hp evo http://videos.streetfire.net/P...F7736
sleepyRPS13
Car: to sleep
another hot car
Engine: Fully built 3S-GE with JE Pistons and Eagle RodsPort and Polished head HKS 272 intake and 272 exhaust camsHKS Cam GearsRC InjectorsXS Engineering intercoolerKoyo aluminum radiator Bosch fuel pumpCustom individual throttle bodies (from a 20valve 4age)Custom induction box (Danstoy)Custom equal length turbo exhaust manifold (Danstoy)Custom downpipe (Danstoy)Turbonetics single turbo (t3/t4 hybrid) with TIAL wastegate (60-1 turbine, 8-20psi capability)**Capable of Roughly 275whp-350whp depending on boost settingsElectromotive TEC3 standalone EMS
I believe my engine swap to be one of the cleanestswaps of this type in SoCal.
Drivetrain:W58 Supra 5-speed transmission ACT pressure plateCustom flywheelSupra Celica rear end with TRD differentialTRD short-throw shifterCustom engine and transmission mounts
Suspension:Custom coil-over sleeves with Tokico HTS dampers Swift 9kg/mm springs frontTRD 8kg/mm springs rearCusco camber platesBattle Version Tension rodsBattle Version RCABattle Version custom Celica Supra 4-link rear linksTanabe Front and rear sway bars
Wheels and Tires: Work Equip 01's in 15x8, -3 offset Toyo T1-S tires
I will be switching to the T1-R tires in the nearfuture as well.
Brakes: (Current)Zeal Super Disc rotors Front: Endless sss pad compoundRear: Endless sss pad compoundTechnafit brake lines.
Endless Big brake kit is in the works and will be done by them time of filming.
Interior: Recaro SPG XL driver seatRecaro Speed passenger seat (Custom colored)Team Tech Red 5-point harnessesPersonal steering wheel with quick-release hubCusco 6-point dash relief rollcage
Exterior: Goodline front bumper with JDM OE sideskirts and OErear bumper. Rear bumper fins from CBYGoodline side-skirts currently on order
If I were to receive the Endless Brake kit, I would be running the J-Blood wide fenders in the front asnecessary.
Body: Complete strip-down and paint by PJ BonafacioPorsche Speed Yellow, two tone yellow and blackbumpersStitch-welded engine bay Flared rear fendersUeo-style 4-point rear strut braceUeo Front Fender braces
chrislis
Car: 1998 240sx sE!
im a sucker for that mr2. i always wanted one.
240sxjeff
Car: nissan 240sx zenki version
Thats got to be the nicest Corolla I have ever seen. The engine bay is so clean and he/she kept the body simple. Its nice to see a ae86 that isnt jDm TyTe DrIfT Yo.perfect example of an old school corolla at its best
dickie
Car: Killer Turtle
wow thats a long list o mods
sleepyRPS13
Car: to sleep
the echo is running the same spring rates as im running 7/8 but is 2320lbs with driver & supercharged. i hope it makes it.
TachyonS14
240DRFT wrote:hey is that white 350z our member hatebobbarker??
Yup, thats him.
