BMC or Booster?
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
ok, my car leaks brake fluid. grrreeeeeat..
it only seems to leak after i turn the car off though, and it'll leak from where the BMC mates with the booster. with the car on, it holds pressure and seems to have good braking power (except for a small leak in rear caliper). any ideas? im thinking the BMC is leaking, but again, just want to be sure.
sjbsuperman1425
CA18DET
also, are manual and automatic BMC's the same or different? just curious?
AZ89two4Tsx
I would just replace them both at the same time.
hungryjoseph
Car: s13 with rb25 and s13 with s14sr20
if it's fluid leaking it sounds like the BMC. and the auto and manual are difference. the auto is bigger than the manual's. makes the pedal more sensitive.
sjbsuperman1425
CA18DET
but both will bolt up correct?
94_240sx
Car: 94_240SX
sjbsuperman1425 wrote:but both will bolt up correct?
That is correct. I have an auto BMC for sale if you are interested. It's OEM one from s13.
hungryjoseph
I will second this. they both do bolt up
