Bluetooth volume
dremmick
Car: 2015 rogue SV
When calling my wife in her rogue her voice is very quiet over Bluetooth and my stereo is cranked. I tried looking in old forums but could not find anything. is there a way to adjust the volume? I have a 2015 rogue sl.
outtolearn88
Car: Rogue SL AWD
Can you clear up your question ? If you are asking about the volume in the ROGUE, just push on the volume up button on the steering wheel. And if y are on the phone by Bluetooth the radio should cut OFF by default......
Hope you can work it out as to fix the problem.
kboo74
Car: 2015 Nissan Rogue SL AWD Premium Pkg (Former)
2017.5 Nissan Murano SL Tech Pkg) (Former)
2019 Acura RDX A-Spec with Tech Pkg Performance Red
You can avoid the headache by plugging in your iphone to the vehicle through the USB port. If you choose not to try adjusting the volume when you have a call in progress. Also check your bluetooth settings on your car's system. Hope this helps.
Ken
dremmick
Car: 2015 rogue SV
I had to turn up Bluetooth volume on the phone.
Return to “Rogue Forum”
