I’m confused about this, does the system show a number when you are receiving a call? I always thought the number only shows up, if you programmed into the Bluetooth system? Or does it work both ways, because I haven’t programmed any numbers and each time I get a call all I see is “Incoming Call” and I have a Nokia 6682 with AT&T..
Can someone tell me how its post to work?
