Bluetooth question
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
So I have 4 android phones. I bought two different bluetooth 4.1 headsets. My problem is when the phones rings, they ring outloud and not just in the headset. I could swear in the past when I bought bluetooth headsets it only rang inside the headset. I can't find any particular settings to fix this. Any suggestions, or is this the way they are now?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
It's going to depend on the android phone and how the manufacturer/carrier have configured things. There may be an option to disable ringing outside the headset. My general experience with Android phones (and I've owned more than a few) is that they always ring the phone itself aloud, even if there's some kind of bluetooth device that's connected for handling calls (car, headset, etc.)
If the phone itself lacks the options you're looking for, you could check out Tasker. It allows you to trigger settings changes based on a number of inputs or triggers, including connecting to any (or a specific) bluetooth device. You could set it to either silence the phone or switch to vibrate only when that headset is connected, and then switch back when it disconnects. Though it's pretty technical, Tasker will work on a stock (unrooted) phone, so no worries there if you're not the hacky type.
darylzero
My S4 only rings through the speakers in my car when using bluetooth. It's only on Android 4.4, so maybe the newer Android OS's have changed things.
Did you go into the bluetooth settings for your paired device?
