Bluetooth problems
Drmacanudo714
Car: 2008 Infiniti M35x
My Bluetooth in my 2008 M35X Sucks! I have tried all the fixes and I am at wits end.
Is there an after market bluetooth system that will work with my factory bluetooth with navigation that will integrate seamlessly and not disable any of my radio/sat/nav functions??
svard75
Car: 06 M35x
So what is the exact issue with the Bluetooth?
Larz
Car: 2019 Q70-L RWD
What kind of bluetooth equipment are you having trouble linking with? a phone? an I-pod? a video player?
Drmacanudo714
The people on the other end/receiving the call can not hear me and it is
Staticky. I cannot use it and have to take it off Bluetooth and return to handheld.
Drmacanudo714
I'm connecting an iPhone 4S. I just want to be able to use my phone hands free.
svard75
Car: 06 M35x
Ah. I believe there is an option to increase the microphone sensitivity within the hidden setup. Search the forums for hidden settings I think for instructions. I think this is how it's performed. Turn off the radio. Holding the setting button down rotate the volume knob a full turn clockwise and the unit should enter settings. Somewhere in there you can turn up the microphones sensitivity.
Drmacanudo714
tried it! Does nothing. Only helps volume. i am willing to replace the bluetooth with an after market one but i want it to integrate like the stock one without disabling any functions that i already have.
svard75
Car: 06 M35x
Sounds like the mic in your headliner needs to be replaced
Drmacanudo714
Is that something I can do?
axefire
Car: 06 Infiniti M35x Navi Tech
Umbria Grey/Burbon Interior
Nah I don't think you can do it - There is/was a recall I beleive tho, check with your dealer!
I had similar problems, especially echoing on the other end - You did go into the diag and setup screen by holding "settings" and turning your volume knob clockwise while the radio is off? Then increase or decrease the incoming volume? Also, when I first start my calls, once the it's ringing I turn the volume (on my radio volume knob) way down and gradualy increase as needed. This minimizes feedback/echoing... I have a iPhone 4s as well, got it working ok...
