Bluetooth Language
cornflakegirl
Hi All!
I just purchased my Rogue today and have been playing around with it all night!
I am having some trouble getting my bluetooth setup -- for some reason the setup instructions are in Spanish! Does anyone know how to reset the bluetooth language to be in English? Is there some place that I can reset all of the bluetooth settings? Thanks!
audtatious
Welcome to NICO...
This should help you out:
cornflakegirl
thank you soooo much! :D :D
audtatious
No problems. Check back often
Hudsonite
Car: 2013 Nissan Rogue
audtatious wrote:Welcome to NICO...
What's the answer? All I see is an ad for a car. I'm having the same problem in my 2013 Rogue, except the language is French. Dealership recommended unplugging the battery. Would that work?
Thanks for the help.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Hudsonite
Thanks, Rogue One. I've memorized that section of the manual and done the inputs at least 25 times. I'll keep searching for help.
Still wondering whether disconnecting the battery would reset the voice to English.
Has anyone ever tried that?
Rogue One
2022 Honda Pilot SE
Couldn't hurt to try it. If your way doesn't work, it's entirely possible you have a defective unit.
audtatious
If following through the steps on page 4-74 of the owners manual does not change the settings then drop by your local Nissan dealership and have them do it for you.
Return to “Rogue Forum”
