Ever Victorious »
https://forums.nicoclub.com/ever-victorious-u44595.html
Thu Oct 11, 2007 1:03 pm
I'm not so sure about that. When the original Vince was sandwiched, the body shop had to take apart the front end (as well as the rear) to repair it, and I'm about 95% certain they removed the battery when they were up there. They did NOT ship the car off to Nissan to have it reprogrammed, and it worked fine after the work was done.
Also, you will not be completely disabled even if I'm wrong. The Immobilizer system is NOT reset by a battery disconnect (because if it was, EVERY Versa that has ever had an aftermarket stereo installed would then have to go to the Nissan dealer), and the immobilizer chip is part of the physical key that separates from the iKey transmitter. This key can be used to unlock, start, and drive the vehicle in case of the failure of the transmitter.
