nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Sat Mar 15, 2008 8:10 am
JWT can tune an ECU to work well. A piggyback will help with fine tuning, but the JWT tune will get you on the road at the least.
My point wasn't about whether OBDII codes would pop up, my point was that the tester will plug in to an OBDII port and not get an OBDII signal. I don't know what that will do with the actual emissions test. Maybe it would assume it's clean, but I bet the tester would show that the OBDII test isn't interfacing with the ECU properly (since you'd have an OBDI harness). Thus, in order for this to work, the car would have to be tested under OBDI, which would mean a conversion that PA may or may not allow/have restrictions on.
