bluebird SR wiring issue B14
dwlf89
Car: 1995 200sx SE-R (bluebird swap)
1993 Sentra (SE-R swap)SOLD
97 Maxima
hokay.I have a little issue with the wiring on my u13 bluebird installation in a b14. I believe this is for the cam position sensor. It looks to me like the stock wiring harness doesn't have a plug that fits this. has anybody out there done this before? i might have to splice some wires...
ok, here's a pic of my car as it was originally....
this is what I'm working with now on the bluebird...
this one is on my B13 sentra.. hopefully it turns out looking something like this....
Any input is appreciated. thanks!
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You must use the oem distributor for the b14 on the U13 motor.
dwlf89
97 Maxima
oooh ok.We'll give that a try. thanks!
Now I just have to find it in my mess of a garage. fun fun
Do you know of any other parts I need to swap over?
RED_DET
Vendor
2011 Infiniti G37x
should should have swapped over the temp sensor as the JDM sensor is diff voltage.
dwlf89
97 Maxima
oh ok. I'll look into that. I do have an aftermarket temp sensor installed and working...
So on another note, What do I need to do about a coil on the distributor??? I see how the connection is made through the cap, but I'm confused by the fact that there's no coil (at least where I would know to look) on the original engine. As the BB has coil right there in plane sight with the wire going to it. this is where I'm like WTF?!?
thanks for your help.... I appreciate it more than you know. I gotta get this thing running.
RED_DET
Vendor
2011 Infiniti G37x
Your B14 wiring harness is different from the b13 because the b14 has an internal coil in the distributor. That is why you have to use your distributor and everything will plug up as it did.
dwlf89
97 Maxima
Very cool. I'm glad you said that. I'll rig it all up and give it a try.
You've been a huge help, I wish I could return the favor!
dwlf89
97 Maxima
ok my distributor is installed and working properly. I have a spark in 4 cylinders. very nice.
No start yet, still troubleshooting.
I have fuel. I have spark. I think the issue is in the vacuum lines.
dwlf89
97 Maxima
well I got it to start but it won't idol on it's own. I have to stay on the gas pedal or it will stall pretty quick. I'm makin' progress. The Engine itself sounds good and solid. No obvious problems
