Bluebird Questions, please help
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
I found a 1994 AWD Bluebird for $1,000! I think this is a great find and I'm gonna jump on it as soon as poss,the prob iz....I wanna find a bodykit for it, can someone show me any bluebird bodykits, or a bodykit that will fit on a bluebird?
chassis #- ENU13engine - 1.8P
And also, will a turbo go to this engine? what size and how much boost can I run? or should I do an engine swap? (hope this engines enuff...)
Thanks in advance guys
jEzTeR
Car: '07 Infiniti FX35
'02 Nissan Altima SE 3.5
'93 Nissan 240SX Hatch
I think the Bluebird looks good as is. No bodykit needed.AWD turbo = :D
PantherRacer
I want a bodykit!!!!!!! ^^^^^^^^ look at it :D I wanna floss, gatta represent if I wan da good gyals in da car lol, I like how it looks too, that's why I botherin, but it needs a kit
jEzTeR
Looks like to me all it needs is some good suspension and wheels/tires + windo tint.
I like smooth simple clean cars.
To each his own though.
twelv
Car: Nissan Maxima
jEzTeR wrote:Looks like to me all it needs is some good suspension and wheels/tires + windo tint.
let's go half and half on this car and clean it you get 6 months out of the year I get the other 6 months. :ylsuper I love the bluebird OWNAGE is driving in the right hand side of the car.
PantherRacer
lol, you have the most pimpinest car man twelv .....custom badging black & silver...DAMN!!! you don't need da bluebird lol
it'd be difficult da 2 a us goin half an half lolol....seein as there's a whole lotta water an some bit a land separating us.... but will like a altima bodykit fit on the bluebird? kit fa da same year?
twelv
Car: Nissan Maxima
It should I don't see why not. once again right hand drive owns me yeah what ever I may be looking to buy a Supra TT for my true beater.
twelv
Car: Nissan Maxima
PantherRacer wrote:lol, you have the most pimpinest car man twelv .....custom badging black & silver...DAMN!!! you don't need da bluebird lol
http://twelv.fasthost.tv/move_0001.wmv
here you go my car in motion just for you.
PantherRacer
keanu reeves impression : "sweeeeeeet....totally wicked awesome" LOL, that's a priceless video man...that's like the ultimate tuner commercial lol
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
jEzTeR wrote:I think the Bluebird looks good as is. No bodykit needed.AWD turbo = :D
Not all bluebirds are AWD and SR20DET…that’s the SSS trim
What he found has a standard CA18DE FWD
PantherRacer
Hey....what is the diff between that awd bluebird, and a bluebird SSS attesa, or jess a plain attesa (if there is a plain attesa)
PantherRacer
Checkered-Member wrote:Not all bluebirds are AWD and SR20DET…that’s the SSS trim
Actually this IS an AWD Bluebird. It believe isn't the SSS, it's just the base level AWD bluebird (if that's what the japanese call it, I'm researching more info on the net.). That's why I asked if there was a diff between the SSS and non SSS awd bluebirds :)
I'm also going to e-mail the company to find out the exact spec's. I'll tell you when and if they reply.
edit: These are the specs they provide for you
Year: 1994 Engine: 1.8P Gearbox: Manual Doors: 4 Seats: 5 Colour: silver Kilometers: 87,000 Grade: 4
Extras: ac, ps, pw, pm, cl, 4wd, ARX-L
(what's ARX-L????? if it was turbo they would have had tb, they might have left it out lol)
PantherRacer
EUREKA I FOUND IT!!!!!!!!!!
GENERAL Body type Hardtop Drive FULL 4WD Transmission 5 speed floor shift Displacement, cc 1838 Frame E-ENU13
SPECIFICATION (SPECS) EXTERIOR Exterior dimensions (LxWxH), mm 4595 x 1695 x 1385 Interior dimensions (LxWxH), mm 1925 x 1420 x 1130 Wheel base, mm 2620 Treads (F/R), mm 1465 / 1455 Ground clearance, mm 160 Curb vehicle weight, kg 1300 Gross vehicle weight, kg Seating capacity, persons 5 Doors number 4 Min.turning radius, m 5.4 Fuel tank capacity, l 63 ENGINE Displacement, cc 1838 Engine model SR18DE Max.power (Net), kw(PS)/rpm 125 ps (91.94 kw) / 6000 rpm Max.torque(Net), N*m(kg*m)/rpm 16.0 kg*m (156.91 N*m) / 4800 rpm Power density 10.4 Engine type Water cooling serial 4 cylinder DOHC16 valve Engine information Fuel system NISSAN EGI (ECCS) (electronic gasoline injection) Turbocharger No Fuel type Unleaded regular gasoline LEV system (Low emission vehicle) No Compression ratio 10 Bore, mm 82.5 Stroke, mm 86 Final gear ratio Fuel consumption at 10-15 modes, l/100km 9 Fuel consumption at 60 km/h, l/100km CHASSIS / TRANSMISSION Power steering Yes Tires size, front 195/65r14 89s Tires size rear 195/65r14 89s Braking system, front Ventilated disk Braking system, rear Drum (leading/trailing) Suspension system, front Independent suspension strut type Suspension system, rear Independent suspension parallel link strut system (sub frame attaching)
:pface:pface:pface:pface:pface:pface TOLD U IT WAS AWD :D:D these are the 93 specs
twelv
Car: Nissan Maxima
OWNED by the search button^^
jEzTeR
AWD is good1.8 w/o turbo is not so good
price is goodgives you something to work on.
Altiman94
Car: 1989 Nissan 240SX
buy it. Dont do no stupid body kit. Get some suspension and a nice wheel/tire package
PantherRacer
That's what I was thinking, get suspension and work on the engine first. I'm still going to get a body kit. not something outrageous though, just to increase the aerodynamics, cuz I WILL beat this car like a b**** :D lol
Any pointers/tips on suspension? I'm still searching google for turbo kits.
PantherRacer
The maker of tha kit said this should be a close fit
and this is what I hope to buy
jEzTeR
That altima is not the same body style so I don't see how that kit could fit?
PantherRacer
yeah I was thinking that, maybe the altima of the same year's bodykit? 94 Altima ~94 Bluebird like this?
PantherRacer
ok, forget the bodykit, unless u wanna input, I'll sort it out with the guy who makes em.
My Question still stands. Can you turbo a SR18DE engine?and where can I find intake, exhaust systems for it? will altima or NX/Pulsar systems fit my Bluebird? I am searching, but it's nice to knw there's a backup (this post) in case my efforts turn up fruitless. THANK YOU in advance.
undertaker
Car: C33
you can turbo that motor but you would be far better off saving for an SR20DET. having said that the two are physically similar and a lot of gear will interchange with minor or no mods (some FWD SR20DE's have quite nice stainless headers standard and turbo manifolds should bolt on), in fact a lot of FWD Nissan parts can be made to fit if you are pepared to modify them a bit.
just to clear up some misconceptions on AWD BB's, the ATTESA can be had with a number of options. I have seen U12's with CA18i (SOHC), CA18DE, CA18DET, CA18DET-R, SR20DET etc. the key is in the model prefix or suffix eg: 'SSS' ATTESA 'Limited'. a SSS will be DOHC and a Limited will have a turbo too. i don't know that much about U13 names but the Ltd is still the one to get ;)
PantherRacer
okay, THAT particular attesa got sold from under me, but I have a backup site :D they're gonna send me their list as soon as they make it.I asked them for their SSS Attesa'sARX-L attessa's and primera t4's and silvia K's
(they should have made an awd silvia)
blubird
no one would buy the skyline if they did:)
jEzTeR
blubird:
Nice car in your Sig! I am guessing that it is yours.
Props if it is...
and can I get a look at some more pics of it please?
