Blue stuff around oil plug - Any ideas?
General discussion area for the L32-chassis Altima
Mark245
Car: 2011 Nissan Altima
When changing the oil on my new (but used) Altima, I noticed that there is a blue/turquoise color material around the oil plug. It looks like some kind of sealer or bonding glue potentially? Anyone know why I would see this or what it is? I also noticed that there seems to be a slow oil leak coming out from this oil plug as well. I torqued the bolt to 25ft-lbs at the last oil change so not sure why there would be any leak at all. I re-tightened and that seemed to help but I'm still wondering if this blue stuff if causing the problem (or hiding some other problem). Any ideas?
Reason: Moved to correct Forum
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's supposed to be a copper crush washer on the plug. Those are infinitely reusable if you don't over-torque the plug, but they become useless and leak if you do. Maybe somebody did, then tried to compensate with RTV instead of getting a new washer.
VStar650CL
Technical Expert
Come to think of it, that doesn't look like an OE plug anyway. The OE plugs generally have no markings.
Yep. Replace the plug, and install a proper copper crush washer... OR, I kinda like the nylon ones, and ALWAYS use a small tq wrench and tighten exactly to spec.
Mark245
Thanks for the help guys. I will buy a new oil plug and washers. Seems like someone at the local express oil change messed up the routine maintenance. That is why I have taken over the maintenance myself and joined this forum!
Return to “4th Generation Altima Sedan (2007-2012)”
