mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Tue Apr 08, 2008 6:00 am
Blue smoke means you're burning oil so, being a TTZ, I wouldn't be surprised if it were the turbos acting up. May also check your PCV valve, make sure it isn't sticking as they can allow oil in.
Its possible it could be an internal issue (rings, scored cylinder wall, headgasket, etc.) but not likely. If you want to check that anyway, a simple compression test should give you a good idea of the internal condition of the engine.
My bet is one of the turbos might be on its way out.
