philipa_240sx »
https://forums.nicoclub.com/philipa-240sx-u68765.html
Sun Apr 27, 2008 5:33 pm
Now you didn't indicate how fast you are accelerating and how long you are letting the engine warm up. Heavy high rpm acceleration on a cold engine (temp gauge at 'C') is a bad thing and will cause excessive engine wear and all sorts of oil consumption/burning issues.
Usually a puff of smoke during acceleration and no other time indicates oil is seeping past the valve stem or possibly via the PCV system. Oil accumulates behind the valves and gets burned off when you accelerate. Constant blue smoke is usually a sign of worn piston rings.
I don't think it's a piston ring or valve seal issue, but there might be something else wrong. I would do 2 things:
1) Have someone else drive your vehicle in the same manner to try and replicate the problem. It would be better to see it with your own eyes so you can replicate the problem with the dealer.2) Check the oil level before you start your car in the morning or at least an hour after your last trip (Make sure the car is on a level surface each time) Timing is important as once the engine is is started, the oil level will drop. Record both the level (as close as you can) and mileage each time. This data will help you and the dealer determine if you have abnormal oil consumption issues.
It's not out of the norm to consume some oil during the break in period, but it should not continue once you have several thousand miles on the vehicle.
