satown210 »
https://forums.nicoclub.com/satown210-u230736.html
Sun Jul 15, 2018 8:45 pm
When using Goof Off, make sure you don't have the Professional Strength one. It will eat paint and clearcoat. I'd start with rubbing alcohol. The harshest thing you can use is fingernail polish remover. Do it on cool paint. If it does not remove the ink fairly quickly, wash the surface where you applied the alcohol or acetone, and then wax it. You will remove any form of wax or sealant that you had prior.
