Blue footwell leds... ([8]pics inside)
Rob.Vegan
Car: 08 2.5S Altima Coupe 76 Datsun 280z (not running)
Not great quality because I don't have a real digital camera, I just borrowed my moms. It's pretty good but not as functional as an SLR or anything like that...
Anyway I have blue leds from oznium (flexible 9") under the dash and above the pedals (one on each side) and two in the back, however the ones in the back aren't wired up correctly so only pics of my two in the front
The switch is just a blue led one from autozone, not very secure but that's not my main concern right now
Looking in w/ window up
Passenger lights
Driver lights
Passenger (lit up)
Driver (lit up)
Passenger floor
Driver floor (and switch)
Both Lit up
mikegtr06
Car: 1995 180sx
looks good
legend_217
Car: 08 Altima Coupe 3.5 black
Hey Rob. It looks really cool man. Are you going to show us how to do it ? You should come down here and install for me yo.
Rob.Vegan
You know I would go down there and install it for you, but honestly I did a half *** job.My brother (mechanic) gets kinda stingy with his tools so I just got some electrical tape and taped the wires together along with crimps.
I couldn't find out how to apply to a fuse so I just mingled the wire from the lights and switch into the fuse holder for the front power socket. everything works fine and has for about a month or two but I don't know how long it will last, I don't want to do your setup and have it blow something out or just do a crappy job in general
If you truly don't mind I am happy to do it for you. I didn't take pics of install and considering my lack of effort I wouldn't really want anyone taking my directions for this so I will not be doing a write up. LBC has a write up on his setup I believe though
However if you have wire (i have some extra) a switch and a solder along with wire crimps and the little things to actually connect wires (forgot what it was called) then sure i'll do it for you
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
someone already did a writeup on this!
http://www.nicoclub.com/articles.php?id=376423
SneakyFish
Car: 2008 Altima Coupe 3.5SE CVT
i was wondering if anyone could tell me what size fuse and fuse holder i would need in order to do the footwell leds?
Rob.Vegan
I rewired these lights finally about a month ago. Everything is good now. It's now correctly hooked up to my front power socket. I used a 15fuse I believe. I can check again if you need to know. I used a 12g wire for most of it.
SneakyFish
would you mind checking, cause i emailed oznium and they told me that a 1 amp fuse would be enough. also with the fuse holder, would i need a 10g since they dont have 12? is it true that i wouldnt need a fuse is i wire into one of the fuses in the fuse box? sorry for all the questions. im kind of electrically challenged
Rob.Vegan
I would trust Oznium over anything I have to say on this situation.
I really doubt you will need a 10g, It depends on how much power you have going through them. After all is done I will be having about 10 lights going to that switch so I figured to start out at a 12g.
The Oznium strips by themselves I think are about a 22 or 24g even, You shouldn't need a wire too bulky.
I will check when I go out to my car and look at the fuse anda get back at you asap
ESP
Car: 2008 SexyBlack A/C
Depending on how many LEDs you've got (and assuming it's not very many) a 1-3amp fuse will be plenty. I've currently got a 5amp fuse for my interior lights, but I've also got quite a few of them and that number is only gonna grow! Rob, 15 is waaay too much for that... haha
As for wiring, Rob is correct. 10ga is overkill. So is 12ga. LEDs draw very little current, so even the much larger 38" strips only have 22ga coming off of them. Personally, I'm using 16-18ga to wire everything in my car, and even that's a bit too much I think!
BTW Rob, lookin' good man!
SneakyFish
alright thanks. you guys wouldnt be able to tell me how to wire it to the 12v or fuse box would you?
Rob.Vegan
Ya I know 15 is overkill but I was i kept grabbing the wrong size fuse for the fuse holder I got and they didn't have much else besides the 15 so I just grabbed that.
I would greatly appreciate it if anyone had info on how to get to the battery most likely through the firewall. I was trying to get through the grommet for like 30minutes to no avail, that's why I just tapped into the cig lighter up front.
Thanks for the compliment ESP I'm hoping to add more real real soon
