Postby
audtatious »
https://forums.nicoclub.com/audtatious-u2438.htmlSun Jul 20, 2008 6:16 am
Plenum spacers fix a potential flow issue from the factory box my raising the amount of air that can be pulled into the upper intake and making it easier for the air to travel to the "starving" cylinders. At least that's what I understand of them
Postby
BrandAidDesignG35 »
https://forums.nicoclub.com/brandaiddesigng35-u84960.htmlMon Jul 21, 2008 7:51 am
I got mine for 120 canadian shipped!
It's louder and slightly more responsive, especially in the Higher RPMS.... I find it lets out a crazy schreech past 5.5 K rpms... really really crazy sounding
Postby
Astro1 »
https://forums.nicoclub.com/astro1-u70206.htmlWed Jul 23, 2008 4:56 am
I threw in the gasket to be sure of the seal . Its only 7 ft pd on the torque wrench to tighten the plenum bolts . use a crisscross tightening pattern so it gets a good seal as well ... there is a vid here somewhere of how to do the install . You may or may not get a check engine light after install .
