Blox Intake Manifold Spacer Review
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
I bought it from here:http://www.jhpusa.com/catalog/...29831
$105 Shipped and it only took 2 days to get here! (Cali > Florida)
The quality is very high! it's made out of that kind of hard plastic that if you were to hit it with a hammer it would dent rather then crack.
it came with all required hardware for the install.
The install took 45 minutes start to finish.
There is a very noticeable difference in sound! the engine roars now when you get on it.
There was a noticeable gain in the mid range (3k-5k) I would say it feels about 10hp (but dyno)
I'm happy for the price, I can't imagine paying $300 for one though... but that's because I'm Poor
Rivalry
I read that the stock strut bar will not fit over a plenum spacer that is larger than 5/16". Did you have any problems?
audtatious
Pix for an upcoming article?
joe603
Car: 2014 Durango R/T
Rivalry wrote:I read that the stock strut bar will not fit over a plenum spacer that is larger than 5/16". Did you have any problems?
The G35 doesn't have an OEM strut tower brace. The engine cover will fit easily with the 5/16 spacer. The 1/2 spacer will require some clever engineering...see Beancooker's FAQ on it.
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Hey! I might be able to fit that into my budget!
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
Well remember this is a 3/4 Spacer... it's the biggest you can get.
joe603
Still might be able to get the cover to fit...
let us know!
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
I don't have the cover anymore anyway.. I can't test.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
says its 5/8" not 3/4...
tollboothwilley
what is the motordyne plenum spacer made from?
those who have the motordyne, your thoughts??
joe603
I have the motordyne, and it was very well made. there is a hard plastic (maybe alloy?) between gasket-like material.
tollboothwilley
worth trying out the BLOX...or MOTORDYNE all the way??
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
tollboothwilley wrote:worth trying out the BLOX...or MOTORDYNE all the way??
Motordyne is not worth the extra money...
The Blox is the same thing for $200 less. I will attest to the quality of the Blox!
tollboothwilley
I'm going to try this out...just ordered it
I'll let ya know if i can get the cover back on without too much trouble
Andy_V35Sky_350GT
Car: 2003 Nissan Skyline 350GT
I know there are a dozen or so different recent threads about spacers, but I was wondering, are the angled spacers better/more efficient than the ones that are equal width?
Also, is it really worth adding a lower spacer/upgrading the plenum also? I noticed the 05+ 350Z's came with an updated lower plenum from factory.
Modified by Andy_V35Sky_350GT at 6:27 AM 1/19/2008
USAF_G35_Guy
Car: 2003 G35 Coupe 6MT
Andy_V35Sky_350GT wrote:I know there are a dozen or so different recent threads about spacers, but I was wondering, are the angled spacers better/more efficient than the ones that are equal width?
I would think that the angled ones are better because the original problem is that the front slopes down, therefore getting less air to the front cylinders as compared to the rear. the equal ones create more air overall, but the angled ones equalize the air distribution over all (if that made sense haha)....at least this is my understanding. I personally just went with a whole new plenum which also fixed the stock problem and is it's bigger in itself, which I paired up with a bored out TB also to allow more air. Just my .02http://www.crawfordz.com/polplenum.htm Plenumhttp://www.crawfordz.com/TB.htm Throttlebody
From the looks of things the Blox would be the way to go as far as spacers are concerned. As long as it's not leaking at all.....a spacer is a spacer IMO. Hell, you could probably lay your stock plenum on a sheet of hardened rubber/plastic....trace around it, cut it out, custom drill your own holes and make one yourself LOL Just do some fine trimming with a razorblade ....now that's the poor mans spacer
trevorluken
Car: 2004 Infiniti G35
I am wanting to order this spacer just a quick question though. Does it come with all the things you need in particular does it come with new studs to put on?
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
trevorluken wrote:I am wanting to order this spacer just a quick question though. Does it come with all the things you need in particular does it come with new studs to put on?
Comes with everything... even stickers the stickers alone add 10HP!!
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
Is it machined, or cast?
You can tell by the finish on it. Machined will have a semi-swirl pattern, and cast will not. This is the one question that I am curious to.
If it is machined, did you check the tolerances from side to side? Is it exactly the same thickness all around?
If it's not, how many thousandths did it vary?
tollboothwilley
I just received mine in the mail....
It looks to be cast. I took a pic in the box it came in.
i'll give my review in a bit
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
Yup it's cast (the plastic has a smooth finish)
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
So what's the concensus regarding the plenum cover and the blox spacer?
Is there a way to make it still fit?
I personally think the plenum is ugly
tollboothwilley
I will let you know about the cover fitting
tollboothwilley
The cover fit after installing the 5/8" BLOX plenum spacer
I modified it slightly.
#1) i took out all 4 metal inserts
#2) I removed the rubber gromets from the 2 holes to the back as that part of the cover will rub on the hood
Works good, feels like its much faster now. Have to speed check more now because i thought I was going 65 and i was going 75.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
tollboothwilley wrote:The cover fit after installing the 5/8" BLOX plenum spacer
$100 is better then $300 right??
I got very negative comments when I fist asked about the spacer "ebay crap" is what they said if I recall
Sentientbydesign
96 I30 - Sold
I like the idea of inexpensive spacer. It's not like the damn thing turns the crank lol.
I read on their website that it's made from a Thermal Polymer. So it's basically a heat resistant plastic.
Once I'm not poor anymore, I'll probably buy one of these. I'm not too thrilled about the idea of the 3/4" one though. I'll probably opt for the 5/8".
Not being able to install a FSTB makes me kind of sad. Especially since my I30 corners better than the G does
joe603
That's what makes the aftermarket so competitive. You get a company that develops a product first (Motordyne) then others "copy" the idea and sell it for less. I do feel that the Motordyne spacer is overpriced...maybe now they'll lower it to compete against newcomers now that they aren't exclusive.
Sentientbydesign
96 I30 - Sold
Sorry to be beating on the dead horse, but is this mod good for both the auto and 6mt plenums?
I am going to order one later today and thought it might be a good idea to verify this.
07g35coupe
Car: 2007 infiniti g35 coupe ivory pearl
Sounds like a nice mod if i was keeping my car
07g35coupe
Same here I think all the moads are revealed once you decide to get rid of your car
