blows fuses
rustest86
Car: 93 240 coupe SR20DET Greddy T518Z, Tomei 256* poncams, sti injectors, and fmi
ok tha story is, i was setting the timming on an 89 sohc 240. i did everything the manuel says to do to set it. but i was reving the engine to make sure it wasnt backfiring through the intake like it was before and the throttle got stuck about half way.......the timing light i have has timing and rpm on it and it said 5600rpm ...... so it was running hard. i have the altanator disconnected because it keep blowing the ignition fuse, no biggie, but when it was screeming like hell i unhooked the battery leads....... the motor was STILL RUNNING! so i opened the main fuse box and yanked the 75amp main fuse, still ran, the i yanked the ecu fuse and it died. now heres the weird part, a couple fuses inside got blown, namely the meter fuse and the room lamp fuse. as soon as i put a new fuse in it pops them. this all happen tonight so i havent had much time to dianose but does anybody have any idea why these two fuses keep blowing, esspecially the room lamp fuse, becouse it has nothing to do with the motor or anything under the hood. anyhow sorry about the long wrightup but i wanted to include everything.
5upra
Car: S197
what are the fuses? The interior lamp(dome light) and the what meter fuse.......try disconnecting battery and plug new fuses in then reattach battery, not guarunteeing anything at all for that but give it a try.
xekushnr
Car: '90 Nissan 240SX Hatch
if the fuses are blowing right after you insert a new one and power is delivered to the circuit, then you have a short somewhere. if you dont have a multimeter i suggest you grab one before going any further.
rustest86
well i found a service manuel in the forums and found that those 2 fuses feed just about every body control module in the car. luckily i have a parts car and swaped a couple out and found out it was the seat belt computer that ws blowing the fuses. anyhow everything is working except for the power door locks and windshield wipers and all the fuses are good no shorted wires that i can find. the wipers didnt work when i got the car, and i fixed it once cant be much to get them working again, but the dorlocks.... i can find anywhere were it says the go through a fuse, relay, or body control module.
