blowned head light?
90ka24de
Car: vRRooommm
hey .. my right passenger side head-light keeps going out on me? keeps blowing the fuse.. what could be wrong or the problem? thanks again
f8sjester
I'd guess that you have a short in the wiring somewhere. Corroded wire sheath or something along those lines. Go ahead and see if you can trace the headlight wires and see if you can find anything strange. If you don't find anything, then I'll let someone else see if they can help you troubleshoot. . . Good luck!
hotshot240sx
Car: my 240sx
check the connector, you may be grounding out intermittenly causing the fuse to blow...does it work in high beam???? cause if it does i can probably bet its the connector
