linuxnut »
https://forums.nicoclub.com/linuxnut-u179636.html
Fri Mar 18, 2011 1:58 pm
UPDATE: Got the pathy up and running again like a champ. It was a very extensive swap but it went along with no major problems. I was to swap out the Top intake plenum, all the coolant lines had to be swap out because they were on the oppsited side from an american car. Changed the water pump, oil pump, thermostat, timming belt, all idaler pullys, belts, plugs, wires. The exshulst manafolds had to be changed, JDM had a mid-ship calilic converter.
Not to bad for a $950 Engine with only 33k miles on it. If anyone needs an engine for a pathy get it from japan. Its a lot of work but it saves you soooo much money with less miles on it. 33,000 is the limit you can buy from japan. They will never be over 33,000.
