Took off comp. housing and saw This!
This pic was before turbo was removed.
Dam! Oil all over around the wheel and collected into the housing cant tell if its coming out through the comp wheel. Idk if there was oil spilling out like that before i set it down for a while or what.
But there was no shaft play, the shaft spins smoothly and there is no oil out on the exhaust side although there was oil in the intake pipe not fresh tho.
Could this be blown seal or crazy blow by and trapped oil from not draining it?
