AAAAAWWWWWWWWWWWWWWWWWWWbaby's got backturbodcivic wrote:
ahhh thank you sooo much dee for your help, i had a clue that it might have been my turbo, so is it just burning water from the seals in the turbo?boost_boy wrote:The only problem you have is a bad turbocharger. Get the turbocharger repaired or replaced, make sure your timing is at 15* BTDC and keep your boost pressure at 10psi or less and your car/engine should be just fine.
Dee
It is the sign of a failed thrust washer as well as a failing turbo seal. I wouldn't waste time with the compression test unless you are just curious. Other than that, your problem is really minor. And the stock turbo is as old as some of the members on this forum, so it is time for it to go bad.turbodcivic wrote:ahh
the turbo is the original stock one, i will do a comp test sat and i guess we'll go from there.
thanks again!!
