gpelite »
https://forums.nicoclub.com/gpelite-u31517.html
Sun Oct 01, 2006 8:08 pm
As most ppl will tell you a TT engine is not gonna be the easiest or most problem free engine, but I have never known it to be a terrible platform either. The bearings, before you drop it in, you could just put new ones on if it is hitting high mileage. However if you leave it be, and you are going to put it under some high stress situations it couldn't hurt
Personally I do not go through bearings like a mad man, but I tend to throw a set on after I do major work on engines that are higher mileage like piston work and changing out cams or workin by the crank. The motto is better safe than sorry, and protect your work. I'm gonna tear down my Z this upcoming summer, new pistons, you bet I will have new bearings so I don't have to go back in there.
They are what, 40.00 or 50.00? Small price to pay to add some longetivity to the engine. God knows its one of the cheaper internals to "spruce" up
bottom line, I would not worry too much. If its gonna bug you, check out what it envolves to replace them and decide from there.
