USMCgetsome »
https://forums.nicoclub.com/usmcgetsome-u15451.html
Sun Apr 10, 2011 2:23 pm
Ok so i just got this mofo going again and when i got it, It had a busted head and the tops of the pistons were impacted a lil. I put back on my apexi metal head gasket -did not resurface block or head (yeah i know i'm a bone head) just to see if it was gonna run again. I think i have the timing set right and get 115 psi across all four. ( used same compression tester and checked my buddies redtop sr he had 150 all the way across). So i know i have low compression.
I bought a leak down tester today and all 4 are leaking. I can hear it in the oil dip stick tube on #2 but it gets wierd. I pressurized #4 and you can feel it leak through #2 as well.
So i'm gonna say i need new piston rings all the way across/ Funny thing is that it runs and drives fine and even holds 10psi boost but i do smoke some out the tail pipe.
VERIFIED THAT THE TURBO IS IN GOOD CONDITION. NO OIL LEAKS AT ALL.
so does anyone have rods/pistons to sell me? OEM plz.
