blown rings question
fallen180sx
Car: 90 Sil80
i have my head off right now.. and my pistons move side to side with effort.. and the cylinder walls are bright shiney silver, and are smooth. my friend said i have bad rings if my pistons move side to side like this.. but the walls i figured would say something..
NeedCAforS13
Car: CA swapped S13 coupe
how far side to side are we talking about here?
Sean
fallen180sx
Car: 90 Sil80
umm about maybe 1/4 of an inch, less probably.. just my guess.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Wow 1/4 inch? I'd say your rings are gone.
fallen180sx
Car: 90 Sil80
nvm, i had my measurements wrong.. and id have to say about 1 centimeter.. or 2.
Modified by fallen180sx at 9:00 PM 1/27/2005
themadscientist
fallen180sx wrote:nvm, i had my measurements wrong.. and id have to say about 1 centimeter.. or 2.
you mean millimeter right?
fallen180sx
Car: 90 Sil80
lol im no good with measurements. im not sure how about this..
|| about half or 3/4 of those 2 bars..
fallen180sx
Car: 90 Sil80
ttt
fallen180sx
Car: 90 Sil80
tt mfn t
biosehnsucht
do this, go find a normal audio CD (not a single or such) and measure the width from one side to the other of the center hole. and tell us, what it measures as, using the same units of measurement AND measuring tool (whatever it was) you used to measure the piston movement, and then we'll know wtf unit of measurement you're using for sure.
fallen180sx
Car: 90 Sil80
the movement was 1mm
NeedCAforS13
the pistons should move somewhat... there isn't really a measurable ammount that is acceptable (because the difference between acceptable and not acceptable is so small). A ring isn't something that wears down like a brake pad. The difference between brand new and really frickin old is extremely small! The only real way to check ring condition is through a compression/leakdown test. BUT since you've already pulled the motor apart, replace your rings.
Pull your oil pan, undo the rod bolts, and punch out the pistons and rods. Replace rings, and rod bearings. Run a quick cylinder honing tool through there to clean it all up. Assemble everything, and have a nice motor
Sean
Vetal
My pistons also moved easily by fingers from side to side about 1.5mm...Where to get cheap rings for CA (I admit I haven't searched yet). Here set of rings is around 210$
boost_boy
I can get you rings a lot cheaper than that. If interested, let me know. But for the other posts, don't use everyday meaurement tactics on your engine. Go and get the proper tools and do the proper measurements by the book. The piston will have very little movement in it's bore.
Dee
Vetal
boost_boy wrote:I can get you rings a lot cheaper than that. If interested, let me know. But for the other posts, don't use everyday meaurement tactics on your engine. Go and get the proper tools and do the proper measurements by the book. The piston will have very little movement in it's bore.
Dee
So if pistons really moved that much, what does it mean?
As for pistons & rings - I'm still trying to choose between stock pistons (and then I need new rings and forged pistons from JE or Arias. Aim would be to go to some 300whp (preferably with the turbo I have now - Mitsu EVOIII Big 16G).How much approx.would be set of stock rings from you?Thanx
boost_boy
Rings are $120 shipped. If your pistons have that much play, then 9 times out of 10 your bores are worn and you're up for an over-sized set of pistons. But unless your oil pump is worn, your wear is not over the limit.
Dee
navara_in the making
Car: nissan navara/laurel
if ur piston rings r gone u will know u should be blowing a bluey whity coulour smoke and a black smoke from ur turbo witch is ok u wont find one that doesnt burn up a bit of oil so i suggest u get some one to go behind u in a car and u give it a boot full and get them to tell u wat they c, if it is bluey whitish then yer it is ur ring or it also could be ur valve stem seals so basicly if ur piston rings move that much then yer its time to change them and i would consider checkin out ur valve stem seals if they feel hard or look dodgy i would advise u to change them while u have got the head of if u can afford to do it all at the same time (less hassel in the long run)
