bioheath »
https://forums.nicoclub.com/bioheath-u32355.html
Thu Sep 08, 2005 4:23 am
OK I was stupid. I didn't disconnect the negative terminal from the battery and I blew something when I hooked the harness up on a radio I was installing.
Here are the symptoms: the clock looses power when the key is turned off. The buzzer (headlights left on, fasten seatbelt, lights left on) stopped working but is slowly coming back, the automatic seatbelts only move when the car is cranked. If you turn the car off before opening the door you are stuck.
I checked the fuses inside and they all look good. Any ideas what to check next? It seems there is a problem with power to things when the car isn't cranked. Is there a common point?
Thanks!
