Blown RB20
foCk
Yesterday I was on my way home when I started a 2nd -> 3rd pull and right about 5500rpm in 3rd I heard a little poof. Ever since then I thought my #6 clyinder was missfiring although everything was testing out fine. Finally I did a compression test and these are my results:
RB20DET w/Tomei 1.3mm Head Gasket
1-1302-1303-1404-1455-1306- 0
StricNyne
that sucks yer the guy with r32 frotn end on yer car right hehe
foCk
used to be now it has a s13 silvia front
im going rb25 now
StricNyne
i got some parts if u need em cheap
jobestudios
Car: (N/A)
Misfiring maybe mistaken for running lean in cyl 6 to heat up the cyl enough to melt a piston or burn a valve? Tear it apart for fun.
johnzm
foCk wrote:Yesterday I was on my way home when I started a 2nd -> 3rd pull and right about 5500rpm in 3rd I heard a little poof. Ever since then I thought my #6 clyinder was missfiring although everything was testing out fine. Finally I did a compression test and these are my results:
dont pull it apart. sell it to me..
foCk
StricNyne what parts do you have?
hey much $$ john?
FAST-DATSUN
have a good long block in stock.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Los, what parts do you have that will fit the 20??
Unless he's gonna stroke it, But I thought you sold your 25 crank.
Buy another long block or buy a 25.Not work building the motor.Costs a lot plus PITA to find parts and wait for them.
StricNyne
i got a rb25 series 2 crank dont need coller, rb25 headgasket and rb26 pistons
foCk
well I have nearly no time to be without a car so I went ahead and purchased a rb25 motorset and i'm going to swap it in this weekend
nismopwr240
Car: RB20 240sx
im needing some rb20 parts and am in charlotte. Please email me at [email protected] thanks
SIL-LINE
Car: S-13 With RB20det
hey fock
what are you gonna do with the 20?
mine is getting a bad idle ...
i may need some parts ?????
let me know ..
thanks
foCk
nismopwr I dont have email at the moment. Which parts do you and sil-line need?
I dunno if i'm going to sell it or rebuild it and then sell it.. We'll see once I tear it all apart.
jobestudios
Car: (N/A)
Yeah, let me know if you're going to part out, I might want to get a few things off you as well! -Jackson
nismopwr240
Car: RB20 240sx
5 spd ecu, j-pipe with bov, and perhaps trannsmission
TONKA
Car: 1989 240sx.
what up guys, kinda new to the forum. Names AL and want to let you know that i am in the works of putting together an RB20. In the works of replacing all the interals for the top to bottom. There are a few things that I am keeping. Just shoot me an email with what you need, and if you would like to see pics.
Sil240
TONKA wrote:what up guys, kinda new to the forum. Names AL and want to let you know that i am in the works of putting together an RB20. In the works of replacing all the interals for the top to bottom. There are a few things that I am keeping. Just shoot me an email with what you need, and if you would like to see pics.
Hey,Welcome to NICO.You should put this in the classified thread up top in the stickies.Instead of Jacking this guys thread.
SIL-LINE
well mine is giving me an idle problem ,
so i would need AAC valve, IACV valve for my idle problem ..
it's also bogging out after four grand so i may need a maf, and the ECU if possible ????
importredneck
Car: 1991 240sx hatch rb20det
Hey had he same problem with number six cylinder and did a nice job on my piston if your not rebuilding it i need just one piston from it
