llamabeta »
https://forums.nicoclub.com/llamabeta-u8998.html
Fri Jul 30, 2004 3:26 pm
Do you mean you turned it on after you replaced the radiator? I hope that is the case. Anyways, if you have white smoke coming out of the exhaust and there wasnt any condensation in the exhaust pipe at the end it sounds like you blew your headgasket.
If it was enough to blow your radiator, I assume you have the plastic top stock piece, then your head gasket probably went before that. I hope its only the headgasket. When my went the head had to be replaced.
When replacing be sure to replace all the coolant componets. Take attentiont to your pump, make sure it hasnt seized.
Good luck.
