Blown Headgasket or Piston Rings what do you think?
callmeweezy724
Car: 1990 240sx w/s13 blacktop swap, 1986 e30 325e 4dr 5spd,1997 infiniti Q45
ok i dont kno if you guys remember me or not, but recently did an s13 blacktop in my s13. I have some bolt-on's, greddy ebc, fmic, greddy rs bov, etc. I'm still stalling when i stop bc i havent hooked up my safc yet and im running an open bov. As of right now im jus givin it a little gass when i slow down to keep it running..i dont think i would be doin that right? It was running fine when i first got it together but now it's burning oil...sometimes ???? I did a compression test and cylinders 2,4 came up low. I can def feel the lost in power..but sometimes the power is there but doesnt stay. However it doesnt overheat at all?? wouldnt it over heat if the headgasket was blown? I asked around and some people said it could be a blown headgasket even tho it's not overheating. I heard that headgaskets can mess with compression too.what do you guys think headgasket or piston rings?? Im hoping its the headgasket lol (fingers crossed)
Hijacker
Car: '92 240sx Convertible
'94 F-150
Blown headgaskets don't always leak coolant. Personally, it's probably pistons/rings. I've seen more imported SRs with piston issues than with head gasket issues due to someone cranking the boost up too much back in Japan.
Justin35ll
Car: s13 coupe sr20det
Yeah, probably piston rings because1. you have low compression which could be headgasket as well, but 2. if you are buring oil that means you could be getting blow by which is oil seeping past the rings and into the combustion chamber causing it to burn oil.
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
A leak down test will tell you whats going on.
callmeweezy724
damn thats something i dont want to hear right now..its gettin crazy cold out. lol yeaa i need to do one of those tests. I was hoping it would be the headgasket so it would be a simple fix i guess i gotta rip it outt if thats the case..
aznrib
Car: 1995 240sx
What were your numbers?
Justin35ll
yeah if it was headgasket you would probably be burning coolant not oil
bruinbear714
What were the compression results?
Burning oil could also mean turbo on its way out.
callmeweezy724
bruinbear714 wrote:What were the compression results?
i did the test a while ago it came up pretty bad i think it was : 125, 25,128, and i forgot the other number ill do it again and repost..
I waas thinking the turbo too bc before i put this turbo i have on now it wasnt smokin at all with the other turbo i had. My compression was good b4 this turbo and everything. It recently started doing this after i swapped to this one. The reason i swapped turbos is bc i blew the oil seal out of my old one. This turbo also doesnt pull as hard as the other one either.
callmeweezy724
will a leak near the oil pump cause the motor to burn oil? or affect the compression in any way after a period of time?
nismonieves
Car: s14
DO AN OIL CHANGE INTO A CLEAR CONTAINER IF U SEE THE COOLANT AT THE BOTTOM THEN U GOT UR PROBLEM
