dhen »
https://forums.nicoclub.com/dhen-u100551.html
Thu Nov 25, 2010 3:40 pm
Hi all,
I have no luck with this car. I just blew my head gasket today and need some advice, but some background first.
My car overheated twice because of a slow leak in the turbo coolant line last week. I fixed that and took it for a drive a few days ago. Good oil pressure and temperature, so I figured the problem was solved. Though I did see white smoke at one time, I diagnosed this as the engine running rich because it went away when I started it up again.
Today I had a hard time starting it, but it's been running rich, so I figured the plugs were fouled. Got it running and took it for a drive. Once it got running sounded fine and pulled great. The water temperature starting climbing and the oil pressure started dropping, so I turned around and went home. The oil pressure was 40 on the highway, but only 5 psi at idle when I got home. For a few seconds it made a scratchy sound on the highway, but this went away very quickly.
I figured I had another coolant problem, and the radiator was about half empty. I figured that the low oil pressure was due to the oil thinning out from the heat. The oil level was fine.
I let it cool down and tried to start it and couldn't. I took the spark plugs out and there was coolant in two of the cylinders. I did a compression check and it was all over the place 120, 100, 100, 130.
OK, so here is my question; do I need a new engine or just a new head gasket? The engine was rebuilt less than 300 miles ago. Is this something that should be covered under warranty, or is it something they'll say I did myself?
Thanks,
Darian
