For the last few days, my truck has given me some problems. blown turn signal here, bad battery cable there, whatever. As I was repairing the battery terminal, I noticed my engine had a gurgling sound coming from the top rad hose. Why is there air in my coolant system? So, I investigate... check my dipstick... that doesn't look right... the fully synthietic oil has streaks in it... check the filler cap... There it was. The dreaded milkshake of doom. Pretty sure the head gasket is blown, as the guy who had it before me put that copper "fix a leak" junk in it when he had it. I flushed my coolant system when I replaced my water pump, and got most of that copper flake out. Now, theres water in my oil. Hmmm... Didn't see this coming.
Advance Auto has the gasket kit for under a 100, and new head bolts are 40. How far do I need to take this resto? I don't have a garage, nor do I have access to a cherry picker, so I don't want to pull this motor if I don't have to. The motor still runs, but I am scared that the main bearings are going to seize up on me with that water in there. Can I just get the slop outta there, clean and degrease it all, then rebuild? Or should I send the head out for machine work? I only paid 500 for the truck, and now I am looking at doubling that price on engine repairs if I have to machine work the whole thing.
