Blown head gasket???
IWANTAKOUKI
Thinking about picking up an s14 but it has a blown headgasket is it hard to replace?? Also the owner says the car wont start is this because of the blown headgasket or something different you guys think?
Gabes13
Car: rb20det s13
IWANTAKOUKI wrote:Thinking about picking up an s14 but it has a blown headgasket is it hard to replace??
Depends how comfortable you are with tools. Rule of thumb though, If you have to ask then yes.
IWANTAKOUKI wrote:Also the owner says the car wont start is this because of the blown headgasket or something different you guys think?
It can be difficult to turn the car over with no compression. Does it at least crank though?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Replacing the gasket is easy. But why is it blown, and did it overheat and warp the head, or deck?
IWANTAKOUKI
good questions how would i know if the motor is still good or if its hurt?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
You really done unless you get the head checked (A machine shop checked to make sure its level, and if not how bad it's warped and will determine if they can resurface the head, if they can they will check the seats by pressure testing, then mill the head if everything is good). Since it's an irion block they tend not to warp as easy, and oyu can clean the deck and check it yourself with feeler gauges and a straight edge.
But there are not certainties. Basically treat it as a "blown engine car" What would you be willing to pay for a car that needs an engine and make an offer from there.
