djtodd »
https://forums.nicoclub.com/djtodd-u5806.html
Sat Mar 29, 2003 2:36 pm
With 100k+ miles on the engine I wouldn't run anything over 225-250hp on factory internals.
A turbo install is not a small undertaking and the most I would run on factory internals is 10psi, most likely 7 or 8. This is about the most you can get on the factory fuel system.With uprgaded injectors and fuel pump you could probably run 10-12psi reliably.
Your looking at about 4 grand plus installation there. This should yield around 225-250hp.
As far as nitrous goes, you could go with a 50 or 75 shot on factory fuel system from what I've heard. Dry, wet, your call.Aeries seems to like the NOS controller, and it's pretty good practice to take his advice. NX and a few others also make kits for your car.
Cams are always a good starting place, but you said you didn't want to do that so...
Anything more than that and you'll need to start replacing internals.
Enjoy, and keep us posted on your progress.
