blown head gasket?
nismo24T
Car: b-ball, 240sx
very odd...here's the story: I was racing a prelude with my 240...smoked em...literally... a cloud of white smoke trailed behind me and filled the cabin...the engine stalls and i park the car to the side...
temp gauge is off the meter...i opened the hood...coolant sprays from the RESERVOIR...the coolant inside the reservoir what I assumed was BOILING or it may have just been pressure...
I check the spark plugs...number four is lightly coated with oil...which explains my slightly rough idle....
I checked the oil...its clean!...doesn't look like chocolate milk...
Any Ideas...leaky valve sea for sure...blown head gasket?
Florida240sx
Check your compression then we can narrow it down.What was the mix of water/antifreeze?Does it start up?Did you drive home?What color was the smoke?
TheOne
Car: 93 240sx FB
i think he said white smoke in his post florida:).
that definetly sounds like coolant burning, but oil in your plugs.....thats another thing.
do a compression or leak down test.
Florida240sx
For some reason I thought I read it was at night so I was wanting him to make sure what color.
nismo24T
Car: b-ball, 240sx
definitely white smoke...same white smoke that i had a problem with before when oil was going in my intake from the turbo....this time...oil was also found in the hot pipe ic piping....what really confuses me is the coolant reservoir....it just squirted coolant to the overfill thing
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
nismo24T wrote:definitely white smoke...same white smoke that i had a problem with before when oil was going in my intake from the turbo....this time...oil was also found in the hot pipe ic piping....what really confuses me is the coolant reservoir....it just squirted coolant to the overfill thing
how does the car drive now?
nismo24T
Car: b-ball, 240sx
oh yeah...it doesn't even start... it turns and tries to, but to no avail...
nismo24T
Car: b-ball, 240sx
it turning...but itss having a hard time...battery charged, starter, everything is fine...except the engine...hmmm??? i deas??
Checkered-Member
Do a compression test, then let us know
fiznat
Car: Grown up :(
Check your plugs while you're at it... and any electrical that may have gotten seriously wet.
Big Manne
Car: cars, muzic, females
seals on turbo?
nismo24T
Car: b-ball, 240sx
electrical is fine...changed plugs...wont start...can i still do a compression test even is the car wont start?...also...i'm crannking it...and a minimal amount of black smoke comes out of exhaust...
Checkered-Member
If the engine is turning, then yes
nismo24T
Car: b-ball, 240sx
yes what?
tryiian
Car: 95 blue emerald s14 KADE traded for 1992 black hatch base
yes you can comp test it.
put comp tester in spark plug`s place, have someone crank car while holding down gas to WOT.
nismo24T
Car: b-ball, 240sx
ok...i'll test it tomorrow...ummm...ne other ideas why it wont start....i seems like its having the hardest time turning over...but it is turning...would bad compression do that?
nismo24T
Car: b-ball, 240sx
it doesn't even turn now...battery is charged...BUT...something weird is happening...the EGI relay is clicking rapidly when i try to start the car...what does this mean....?
...could my walbro fuel pump be blown?
nismo24T
Car: b-ball, 240sx
and ... i thinnk its the fuel pump, but it is coming from the trunk ... it sounds like a frog croaking .... ?
nissanfanatic
Car: 1992 Nissan 240sx SE
ACtual compression PSI won't be very accurate, but large differences will tell you where the problem is. Leak-down will show a blown head gasket much better becasue you can listen for air leaking.
nismo24T
Car: b-ball, 240sx
the fourth cylinder has no compression...it didnt even move the fricki needle....all the others were around 128....??? head gasket huh?
bruinbear714
Most likely... white smoke = burning coolant, and #4 cylinder is dead - it's the most likely out of the 4 that goes...
