elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Mon Jul 05, 2004 5:14 pm
The 2000+ engines are still experiencing some problems, but most arent at high enough mileage to tell.. they have improved...
However, the major problem with them is the Crank angle sensors... They are still backordered, they cant mae enough of these.. I believe its a TSB.....
No one to my knowledge has blown an OBDII northstar.....
Again, even if you COULD boost the piss out of it (which it cant take as mucha s the VH, weak heads across the years) you would be limited by traction...
Thers a guy on the caddy forums with a 97 ETC and he's put a 175 shot of nitrous on it (dont know details) and even with that he didnt have full traction at all throughout the run... he said he had bad tires but he kinda had to limp it down, enver got to really put down the hammer.....
So basically, the limiting factor to the boosting of a norhtstar is the FWD setup..... HOWEVER, you can convert them into RWD...
The isuzu troopers (not sure on years) have the same bolt pattern and its a bolt on except for you have to relocate one bolt near the starter...... You can use the rearends from them and bolt it right up...... Obviously thered need to be some serious mods to be done but its certainly not out of reach and could be done somewhat economically.. i dont think much frame work woudl have to be done, if any, theyd just have to make a spot for the transmission but I think it wouldnt be a big deal if you place the engine far enough foreward...
Other than that, youd just have to make custom mounts, and rerun most of the hoses and such.....
