slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Thu Dec 09, 2004 3:55 pm
Check your trunk/hatch interior light(s) if you have 'em. That stroller flopping around in the back could have beat the bulb socket up pretty bad.
The only other wires that would be remotely related to that fuse could be the sound system; you mentioned it was a hatch, so I doubt you have the active(amplified) factory stereo system. You don't even have deck speakers do you? If you have any type of speakers in the trunk, pull your head unit/audio source: it's unlikely to happen, but a shorted speaker wire can pop a fuse(because the head unit/source is pulling too much current attempting to drive a shorted load).
My money is on an interior bulb...HTH,-Slip
